Front bump stops
  • topjimny
01 May 2013 17:03 #69813 by topjimny
Front bump stops was created by topjimny
Hi guys,
I'm looking for some ideas at extending front bump stops. Has anyone been through this?
Thing is i got some bad rubbing (only when hitting really big bumps) and want to avoid body lift or arch trimming.
Thanks
  • markyp2000
01 May 2013 20:22 #69830 by markyp2000
Replied by markyp2000 on topic Front bump stops
Rear bump stop fitted with a spacer then a treaded bar up the middle with a nut at the top thats what im planing on doing but if its to big you wont get the spring in
  • topjimny
02 May 2013 01:00 - 02 May 2013 01:01 #69848 by topjimny
Replied by topjimny on topic Front bump stops
You mean at the bottom (to work with the existing top one)?
Last edit: 02 May 2013 01:01 by topjimny.
  • markyp2000
02 May 2013 07:05 #69851 by markyp2000
Nope
03 May 2013 21:06 #69939 by kirkynut
Replied by kirkynut on topic Front bump stops
Bits4vits do a bump stop extender, not sure if it'll work on the front as not really looked recently and my memory is not what it used to be...... During the war.......
The following user(s) said Thank You: topjimny
  • Tadpole
04 May 2013 07:15 #69956 by Tadpole
Replied by Tadpole on topic Front bump stops
kirkynut wrote: ...... During the war....... Kirkynut
Is that with a 'cockney accent' Kirky ................ :lol:
Time to create page: 0.172 seconds
