Misfire error code - but no misfire!
  • discotroll
01 May 2013 11:55 #69804 by discotroll
Misfire error code - but no misfire! was created by discotroll
Hmmm.. this is a tricky one.
Got my soft-top 02 model Jimny (older single-cam engine) back and running and sorted a dodgy EGR Valve and the little Jim seems very happy. Only problem is that about every third trip out the engine mangement light will come on with an error code of 'misfire in cylinder 4' or sometimes 'random misfire in all cylinders' - I can clear the codes but after about 3 or 4 trips it'll come up again.
Thing is, it doesn't ever feel like it's misfiring at all or struggling where slow/fast hot or cold.
I'm thinking of swapping the lower sensor (crank position??) that the soft top has postioned at the front of the oil sump as as starting point - does anyone know if this is different to the one used on the standard hard-top Jimny? Obviously if anyone's got any ideas on this strange issue please let me know as it's quite frustrating....
Thanks,
DT.
  • UKDAN
01 May 2013 12:33 #69806 by UKDAN
Replied by UKDAN on topic Misfire error code - but no misfire!
Sounds like a coil pack fault
Dan
01 May 2013 21:16 #69839 by Rhinoman
The ECU can detect a misfire that isn't really noticeable. It may just need a service recently if it hasn't had one for a while.
  • discotroll
02 May 2013 18:40 #69870 by discotroll
Replied by discotroll on topic Misfire error code - but no misfire!
It'll be no surprise if it can be that sensitive - I had the engine out on the drive and was swapping broken pistons a month back so a proper service and tune-up looks like it might sort me out....
Time to create page: 0.174 seconds
