Alloy Dustcaps
- Northern-Wanderer
30 Apr 2013 19:12 #69758
by Northern-Wanderer
Alloy Dustcaps was created by Northern-Wanderer
Last November i bought some alloy dustcaps and fitted them.I December i broke my kneecap so the Jim has just stood for approx 20 weeks.Today i went to check the tyre pressures only to find that the caps had corroded to the valve stem and would not budge.I ground them off in the end, but had i been away from home and wanting to adjust the pressures i would have been well and truly stuck.If anyone else has these caps make sure you an use anti seize product before fitting and save yourself a lot of time and bother.
- adamjimny
30 Apr 2013 19:28 #69759
by adamjimny
Replied by adamjimny on topic Alloy Dustcaps
this is why i only use plastic ones
- darthloachie
01 May 2013 09:26 #69795
by darthloachie
Replied by darthloachie on topic Alloy Dustcaps
you just need to find a local chav - he'll have them off in seconds!!
- JivingDaddy
01 May 2013 09:46 #69796
by JivingDaddy
Ha, ha. :laugh:
Replied by JivingDaddy on topic Alloy Dustcaps
darthloachie wrote: you just need to find a local chav - he'll have them off in seconds!!
Ha, ha. :laugh:
01 May 2013 13:03 - 01 May 2013 13:05 #69809
by Halford
Replied by Halford on topic Alloy Dustcaps
rubber gloves for more grip, failing that, gentle use of mole grips :pinch:
think the chavs just use their two remaining teeth :S
Last edit: 01 May 2013 13:05 by Halford.
- reaper
01 May 2013 19:54 #69824
by reaper
Replied by reaper on topic Alloy Dustcaps
The wife once put some on her micra . . . .i riped the valves out trying to getbthe dam things off :pinch:
Time to create page: 0.158 seconds
