410 transfer box mounting
  • RichiesJimny
13 years 6 months ago #69721 by RichiesJimny
410 transfer box mounting was created by RichiesJimny
Having purchased a 410 transfer box I'm torn between the Rockwatt bucket mount or the ora mounting kits, they both cost around the same as each, which do you use and what do you think of them.
  • supergaz
13 years 6 months ago #69732 by supergaz
Replied by supergaz on topic 410 transfer box mounting
I have the earlier ORA mounts, no problems with them, But Rockwatt does a 27 tooth speedo correction gear for bigger tyres which ORA do not offer.
I would choose Rockwatts and will more than likely change to a Rockbucket soon.
I just got my Rocklobster totally refurbed by Richard along with the 27 tooth speedo gear and am very happy.
13 years 6 months ago #69757 by Johnniehec
I'd go for the Bucket as well, the heavy duty steel mounts will mean if you stress it it'll break the side out of the box rather than the mount. Still got original Jimny box in mine with standard brackets for that very reason (I've broken three mounts) Definitely bucket when I get round to different box in mine!
John.
  • g187eev
13 years 6 months ago #69763 by g187eev
Replied by g187eev on topic 410 transfer box mounting
If you don't mind me correcting you, our brackets pick up on an additional 7 bolts on the casing over stock ensuring you will not tear out the side of the casing. Also by picking up on the 4 bolts around the rear output flange this braces the box in the opposite plain greatly increasing to rigidity of the mounting system and preventing twisting on the mounts.
RB
ORA
Time to create page: 0.103 seconds
