Clutch Changing?
- SteBurns
29 Apr 2013 15:54 #69703
by SteBurns
Clutch Changing? was created by SteBurns
My Jimny is due a new clutch, and I've got several options...
- Buy a clutch off eBay or similar and let my mates try and fit it in their spare time.
- Pay a friend who's a mobile mechanic to come and change it.
- Take it to a garage and leave it with them.
- Ask on forums (here) for someone who'll fit it cheap.
Here are my questions...
- Are Jimny clutches easy to change being high off the ground with good access?
- What kind of clutches are they, hydraulic or cable?
- Are generic eBay clutches any good?
Also, do you guys have any suggestions or advice? I'm not a mechanic but all my mates like getting their hands dirty, but don't have much spare time on their hands!
- Basketcase
29 Apr 2013 20:23 #69723
by Basketcase
Replied by Basketcase on topic Clutch Changing?
the clutch is easy to change, if i was you id get a clutch from euro car parts theyre abour £80 and theres a how to guide on here that details exactly how to do it. Its a cable operated clutch also it took me about 9 hours altogether to swap my gearbox and clutch and i'd never done anything this indepth before took me so long because i didnt have the correct tools or enough of the tools i needed a long pry bar and a 14mm socket with a big breaker bar to undo the awkward gearbox bolts took me a while to get the gearbox out and back in again (changing the clutch doesnt have this problem just pull the box back as far as you can) id say its ok for a diy fix yourself i managed to align the cluth with my eyes as the gearbox was out of the way i just got my head where it should have been but you can get clutch alignment tools if you want to do it that way
hope this helps!
hope this helps!
- gus2000
30 Apr 2013 12:41 - 30 Apr 2013 14:45 #69746
by gus2000
Replied by gus2000 on topic Clutch Changing?
Hello, I’m suggest use only Suzuki genuine parts
Clutch cable
Clutch plate and disc (AISIN), and bearing
Oil seal gearbox
Replace gearbox lever command oil seal
Change
Disassembly
Older clutch
Change Ball bearing (pilot bearing)
Assembly - center disc with especial tool
Replace oil seal crankshaft, and tighten the bolts to the specified torque. use threadlocker
Requires a car lift, centering disk tool and Torque Wrench to do a good job
Success
Clutch cable
Oil seal gearbox
Change
Disassembly
Older clutch
Success
Last edit: 30 Apr 2013 14:45 by gus2000. Reason: denomination error
- gilburton
30 Apr 2013 14:18 #69748
by gilburton
Replied by gilburton on topic Clutch Changing?
Time to create page: 0.301 seconds
