Bubbling coolant!!!
- bazzab
27 Apr 2013 22:21 #69576
by bazzab
Bubbling coolant!!! was created by bazzab
Hi all,
Im fairly certain i know the problem, but im a strong believer in second/third/forth etc opinions. So my jimny has started using coolant and has got bit worse.
Have bleed system etc, had fair old look about for leaks and no sign.
Symptoms are, using coolant, and i can hear a bubbling, it only seems to happen when i turn the car off and only for few seconds. It doesn't over heat and there is no sign of steam from exhaust. Oil is fine.
So what's ya thought peps?
Very grateful for any input.
Bazza.
Bazza.
- mudman
27 Apr 2013 23:21 #69590
by mudman
Replied by mudman on topic Bubbling coolant!!!
what dose your temp gage say and check your rad if you use it off roaf it may be full of mud i had this untill last week so i changed my rad now its fine
- goatboy
28 Apr 2013 07:24 #69592
by goatboy
Replied by goatboy on topic Bubbling coolant!!!
The obvious conclusion is headgasket but I wouldn't jump to that conclusion too fast.
Like Mudman says If the rad is blocked up with gunk this could happen too.
- bazzab
28 Apr 2013 11:10 #69606
by bazzab
Replied by bazzab on topic Re: Bubbling coolant!!!
Thank you chaps.
Was leaning towards head gasket. But can't be arsed Hahaha.
So if rad is blocked up would do same thing??
Temp gauge is fine sits bang on in middle and stays there.
- mickt
28 Apr 2013 14:20 #69622
by mickt
Replied by mickt on topic Bubbling coolant!!!
Pressure cap not sealing properly??
28 Apr 2013 15:17 #69629
by facade
Replied by facade on topic Bubbling coolant!!!
What is happening at the overflow tank? Is the coolant on the mark when cold? Where is the level when hot?
