clunk!
- Skinhead
27 Apr 2013 22:02 #69574
by Skinhead
clunk! was created by Skinhead
My jimny is making a clunk noise when setting off/accelerating and when taking foot off accelerator, i think its coming from the rear. Any ideas what it could be? Its got new wheel bearings on both sides so dont think thats the problem.
- bazzab
27 Apr 2013 22:22 #69577
by bazzab
Replied by bazzab on topic Re: clunk!
Have the same thing bud. So be interested in replys.
- UKDAN
27 Apr 2013 22:36 #69582
by UKDAN
Replied by UKDAN on topic clunk!
Rear diff ? LR Freelanders are known for that symptom, just a thought.
Dan
Dan
- gus2000
27 Apr 2013 22:56 #69587
by gus2000
Replied by gus2000 on topic clunk!
Hi, many suzukis have a excessive backlash between teeth of planetary and satellites of diff.
In my Jimny the solution showed up when changing the rear differential by new one (ARB locker)
The "clanck" was solved definitively
Also check cardanic joints, homocinetic joint, and ajust between ring and gear of differential.
Success
Gustavo
Success
Gustavo
- mudman
27 Apr 2013 23:17 #69589
by mudman
Replied by mudman on topic clunk!
iv just solved the same problem check your radius arm bolts mine were loose and make shure the hole havent elongated mine have started
- markyp2000
28 Apr 2013 07:27 #69593
by markyp2000
Replied by markyp2000 on topic clunk!
Gear box mount. transfer box mount. prop shaft joint. Engine mount. The nut loose be hind the wheel
