HELP - changing kingpin bearings - SEALS
  • topjimny
26 Apr 2013 16:52 #69531 by topjimny
I got bad kingpin bearings on one wheel (front left). I need to know what seals are need or recommended to replace in this job. Attached is an image of the candidates.
Thanks guys
26 Apr 2013 18:45 #69533 by j999pre
No3. This is included in martins kit in the shop along with a set of bearings all for £24
Grey pick up Jimny
The following user(s) said Thank You: topjimny
  • topjimny
26 Apr 2013 21:04 - 26 Apr 2013 21:06 #69540 by topjimny
Replied by topjimny on topic HELP - changing kingpin bearings - SEALS
Just n.3 then? What about the others when it's time to reassemble everything?
Last edit: 26 Apr 2013 21:06 by topjimny.
  • dirtydogz
27 Apr 2013 10:26 #69552 by j999pre
topjimny wrote: Just n.3 then? What about the others when it's time to reassemble everything?
Use the pdf guide posted above. You don't even have to take the back plate or vacuum hub off if its just the kingpin bearings.
Track rod ends (1 or 2) 8 rear seal bolts and 8 kingpin bolts. Other seals are for wheel bearing our vacum problems.
You could do the big wiper swivel seal but unless its badly torn/worn most people just refit it.
Remember new grease and sealant on the kingpins.
Simples!
Grey pick up Jimny
  • topjimny
29 Apr 2013 10:52 #69680 by topjimny
Valeu!
Abraço!
Time to create page: 0.094 seconds
