410/413 transfer box
- RichiesJimny
13 years 6 months ago - 13 years 6 months ago #69464
by RichiesJimny
410/413 transfer box was created by RichiesJimny
I may have found a 410 transfer box the guy tells me it's defiantly a 410 box because it has a transmission brake on it. Am I right in thinking the 413 transfer box also has a transmission brake fitted to it.
Last edit: 13 years 6 months ago by RichiesJimny.
13 years 6 months ago #69465
Replied by mlines on topic 410/413 transfer box
Correct, both 410 and 413 SJs can have a transmission brake so its not a definitive test. Some 413s did have a conventional brake.
- jb32suzuki
13 years 6 months ago #69468
by jb32suzuki
Replied by jb32suzuki on topic 410/413 transfer box
I've been doing quite a lot of research the last few days on 410 and 413 transfer cases.
Here's one document in particular that I found:
www.sp-suzuki-breakers.com/USERIMAGES/rocklobster.pdf
From the bottom of page 1:
Hope this helps.
Put the transfer box into Low Ratio gear and then turn the OUTPUT flange. For one complete turn of the output flange count the turns on the input flange. If it is a correct 410 box you will get 2.5 turns (in "clock" turns that's 2 hours and 30 mins). If it is a 413 box you will get 2.1 turns (in "clock" turns that's 2 hours and 6 mins).
Hope this helps.
Time to create page: 0.076 seconds
