speedo correction
  • med
24 Apr 2013 09:56 #69367 by med
speedo correction was created by med
No eBay APP ID and/or Cert ID defined in Kunena configurationanyone know if this would work on my jimny to correct the speedo after fitting 30" tyres?
i know a few of you guys have used the Jaycar one but they seem to have taken it off there UK website..
Thanks
Tom
  • UKDAN
24 Apr 2013 11:33 #69370 by UKDAN
Replied by UKDAN on topic speedo correction
Have a look at www.4x4tyres.co.uk top right corner of the home page is the tyre size calculator which show size you have & size you want next to it with all diameters, wall sizes etc. and at the bottom shows how much your speedo will be out by at any given speed.
  • gus2000
24 Apr 2013 15:09 #69380 by gus2000
Replied by gus2000 on topic speedo correction
Hello, in my archive I keep this circuit........ :dry: I do not remember its origin :dry:
more info.....
www.jaycar.co.nz/productView.asp?ID=KC5435
I prefer to change the number of teeth on the speedo gear (inside the t-case)
Gustavo
  • supergaz
24 Apr 2013 15:59 #69381 by supergaz
Replied by supergaz on topic speedo correction
With tyres of that size I assume you have gone down the Rock Lobster route, Then you can contact a nice guy called Rockwatt on this forum and he can supply a 27 tooth speedo ring that will go on the rear output flange on the SJ box. The jimny transfer case has a 25 tooth speedo ring.
  • med
24 Apr 2013 16:33 #69382 by med
Replied by med on topic speedo correction
cheers for the coments guys.
i think it still has standard t box, when i bought it it has 31"s on it with 3" lift and 2" body lift... the 31's where massive so i have downsized to 30s.. only doing a bit of green laning really, if it breaks then may build up a rocklobster for it, will see how it goes..
i was just wanting to sort the speedo out for road use.. could put stickers on the dash but id rather do it properly!
thats why i wanted to know if the adaptor on ebay would work the same as the jaycar one and i can just wire it inline to speedo and adjust!
cheers
Tom
  • ilten
24 Apr 2013 17:30 - 24 Apr 2013 17:31 #69385 by ilten
Replied by ilten on topic speedo correction
I'm running 30's and 31" on mine and I use a speedohealer.
www.healtech-electronics.com/
Fantastic bit of kit. Easy to install and does what it's supposed to do.
They even have a android app for your smartphone that guides you through the setup process, although it isn't overly complicated and can be easily done without it.
ilten
Last edit: 24 Apr 2013 17:31 by ilten.
Time to create page: 0.197 seconds
