What did you use?
18 Apr 2013 15:59 #68970 by Obarno
What did you use? was created by Obarno
On my Jimny trialler I have recently removed the plastic trims that cover the cills. They are held on with some plastic clips that fit into square holes in the cill. I tried just refitting the clips but they are not a tight fit and I think that the cills will fill up with mud and water. I tried putting silicon in the holes but that didn't really work. So any ideas or info on what you have used greatfully received.
  • vitara_mad
19 Apr 2013 06:59 #68998 by vitara_mad
Replied by vitara_mad on topic What did you use?
small bolts,nuts & washers
  • barnes
19 Apr 2013 09:52 #69002 by barnes
Replied by barnes on topic What did you use?
Tigerseal is a good for sticking things and its water tight
19 Apr 2013 14:30 #69017 by Obarno
Replied by Obarno on topic What did you use?
Thanks for your ideas - pardon my ignorance but what's tigerseal?
  • Smoggy
19 Apr 2013 14:52 #69018 by Smoggy
Replied by Smoggy on topic What did you use?
I have exactly the same problem to overcome. I don't fancy bolts if I'm honest, I was going to weld them up and gring the welds flat chewy but effective (fortunately I bought some chequer plate sill covers from Kap to cover most of them).
19 Apr 2013 15:33 #69026 by Obarno
That looks like excellent stuff MysticRich.
Thanks for the ideas.
Time to create page: 0.172 seconds
