Jimny Boot Rust!
- Fyffe
16 Apr 2013 14:44 #68814
by Fyffe
Jimny Boot Rust! was created by Fyffe
I have a couple of spots in the boot where the jack goes where its rusted through. i haven't had much experiences with blagging cars through so was looking for a second opinion.
I was just thinking about using the old chemical metal and chicken wire approach once painted over you guys reckon that will pass through an MOT?
Im fairly confident it will but a second opinion never hurts!
Thanks in advance guys!
- adamatdraycott
16 Apr 2013 14:54 #68815
by adamatdraycott
Replied by adamatdraycott on topic Jimny Boot Rust!
Its non structural so won't fail.
Its a known Jimny fault... and if you go out to buy a 2013 model, wait 5-6 years and that will rust too because the design hasn't changed since 1998
- Fyffe
16 Apr 2013 15:01 #68816
by Fyffe
Replied by Fyffe on topic Jimny Boot Rust!
Oh right perfect! just out of curiosity is there any place that are likely to rust on a jim that will result in an MOT failure?
- adamatdraycott
16 Apr 2013 15:23 #68817
by adamatdraycott
Old ones especially rust behind the headlights... which i don't know, but assume that may mean a fail due to impact/crumple zones etc. Older examples also suffer from brake line rust, and also vacuum pipes fro the free wheeling hubs.
The whole boot floor is prone to the old tin worm especially around the rear seat belt mounts... which again will result in a failure, unless the belts and seats are removed i guess :dry:
Several areas of the chassis will appear scabby, but this tends to be surface rust only.
Although i have seen one chassis in specific that was fairly shot!
- markyp2000
16 Apr 2013 17:53 #68826
by markyp2000
WRONG IN A BIG WAY
If there is any rust holes within 30cm 12" in old money lol of the body mounts seat/seat belt mounts then is should fail it its being tested correctly
Replied by markyp2000 on topic Jimny Boot Rust!
adamatdraycott wrote: Its non structural so won't fail.
WRONG IN A BIG WAY
- gilburton
17 Apr 2013 11:46 #68878
by gilburton
Replied by gilburton on topic Jimny Boot Rust!
Don't forget the later ones are zinc coated so it might help preserve them a bit longer??
Just a thought but has anyone considered the effect of the rear silencer on causing rust??
i.e. condensation being caused by the constant heating up and cooling down???
