I need more flex any help is nice
  • TonkaTough
16 Apr 2013 10:02 #68793 by TonkaTough
I need more flex any help is nice was created by TonkaTough
So I have a 2" lift in my jimny with 6" extended shockers flexes awesome in the front but binds up well before shockers bottom out and the back is crap it binds up and won't drop any more if I put castor correction bushes in it will it help or do I replace the arms
  • TomDK
16 Apr 2013 11:54 #68805 by TomDK
Replied by TomDK on topic I need more flex any help is nice
How do a 2" lift work with 6" extended shocks?
If you want more articulation, fit the 4" ORA kit.
  • mudman
17 Apr 2013 00:29 #68853 by mudman
Replied by mudman on topic I need more flex any help is nice
try +3 springs, extened your bump stops to help push the axle down and remove your anti roll bars and i hope your running extended brake lines :lol:
  • adamjimny
20 Apr 2013 01:51 #69065 by adamjimny
Replied by adamjimny on topic Re: I need more flex any help is nice
I know what you mean i have same problem.
Cc bushes wont help though
Its the radius arms binding....the bushes fully flexed and arm limiting it now. Im changing how mine link to improve it which is the only option for you also now if you want more.
Get it on full flex and look at radius arm mountings and to will see the arm bing against these.....its stopping more travel
Sent from my GT-I9300 using Tapatalk 2
20 Apr 2013 09:50 - 20 Apr 2013 10:51 #69081 by kirkynut
What exactly is it you are looking for when you say you want more flex?
I say this because a standard Jimny will stuff one wheel up in it's arch till it hits the bumpstop and dangle the other in the air if there's nothing under it.
If you put longer springs on the car the wheel will still be pushed up into the arch in the same scenario but not as far into it because the spring is longer. The wheel the other side is unlikely to dangle any further down and touch the ground to give traction as the first side is not pushing against the bumpstop levering the axle to push the second wheel down.
The benefit of longer springs is being able to fit bigger tyres. Bigger tyres give you more ground clearance. Also, in the scenario above, because the second wheel's tyre is bigger it has more chance of touching the ground as it dangles in the cross axle scenario and getting traction to keep going.
If you extend your bumpstops with your springs, you'll allow the first side to touch the bumpstop and lever the other side further down so it touches the ground to give traction instead of hang in the air.
The length of your shocks governs how far the second side can drop, so having shocks that match the longer springs is obviously necessary. However, if the shocks are too long the springs can dislocate and fall out on side two in the above scenario, or get over compressed and be damaged on side one in the above scenario.
To stop rear springs dislocating, ORA sell clamps for the bottom of the springs and the bumpstops act as dislocation cones. There is questionable benefit to dislocating springs as there is nothing but the weight of the axle pushing the tread of the tyre into the ground to gain traction. That's if it's touching the ground that much.
X-Eng provide a solution to this issue for Landrovers in the form of their X-Springs and Simon probably explains them better than I do on his website.
Ultimately though, the best thing to do is to add locking diffs to your Jimny, spending the money on them rather than trying to get ultimate flex but do still buy good suspension though.
As has been mentioned, the ORA 4" kit is about the most complete kit out there and Rob Butler has spent time and experience deciding what's best. I think this is the ultimate kit without going too far. I would only add extended bumpstops but that's probably not necessary.
I also rate Superpro bushes as the rubber ones flex nicely but are not long lasting as a result.
[IMG
The above photo of mine demonstrates what I'm saying - the passenger wheel is stuffed right up on the arch and this one is drooping right down - great flex, but to what benefit? I've got best part of a foot of air under this wheel!
Or just have a friend run around with you who can pull it down to the ground like I do!
[IMG
Click on the image to play the wideo in Media Player.
Last edit: 20 Apr 2013 10:51 by kirkynut.
  • iloveics
20 Apr 2013 19:34 - 20 Apr 2013 19:37 #69103 by iloveics
Replied by iloveics on topic I need more flex any help is nice
@kirkynut. agreed.
this says it all
the 90 is articulating massively, but it still can't get up it...
Last edit: 20 Apr 2013 19:37 by iloveics.
