hub/king pin
  • stevenb
13 years 7 months ago #68457 by stevenb
hub/king pin was created by stevenb
right lads a wee question for u can u take the hub off with out pulling it apart
i need to replace the king pins and hub seal but strugleing to get the hub off i don,t realy have the cash to pay the garage so need to do this myself
cheers lads
13 years 7 months ago #68458 by mlines
Replied by mlines on topic hub/king pin
You can remove the hub without splitting it at the Disc backing plate (despite my guide saying you have to do this)
Which bit are ou struggling with?
13 years 7 months ago - 13 years 7 months ago #68462 by facade
Replied by facade on topic hub/king pin
There are plenty of posts on this, but I did it without complete disassembly.
From memory:
Jack up that side to keep the oil in
Split the steering joints at the tapers
Remove calliper
Remove freewheel hub.
Remove circlip and washers from the end of the CV splines and the Shaft pushes inwards.
Remove the small bolts holding the dust seal cover on the inside of the swivel housing, remove dust seal
Remove 4 bolts top & bottom from kingpins, remove kingpins.
Hub now pulls off complete, and the halfshaft will stay behind if you took the circlips off.
Pull halfshaft out
Clean CV joint
Remove and replace top & bottom bearings and axle seal.
Reassemble.
Takes a couple of hours.
45 minutes if you work fast and someone keeps handing you the correct tools and tidies up after you.
If you have ABS you cannot do this, as the ABS sensor doesn't plug in and has to be removed first, or left swinging on the wire if long enough.
Last edit: 13 years 7 months ago by facade.
  • stevenb
13 years 7 months ago #68487 by stevenb
Replied by stevenb on topic hub/king pin
ah cheers for that lads i,ve been trying to get on reply to u for this most off the day but this is the first time i have got on , martin i,m struggleing getting the hub off i have taken the circlip off and undone the specail nut but the hubs tight on plus the dust sheild is rusted to hell so is the bolts that hold it on .at first i couldn,t get the brake caliper carriers off as a bolt had been tottaly rounded now i got it off something else is anoying me lol
  • markyp2000
13 years 7 months ago #68497 by markyp2000
Replied by markyp2000 on topic hub/king pin
Do as facade says there is no need to undo the hub nut and dont for get to take the steering joints off makes it a bit easyer where ae you located some one may be local to you on here and is able to give you a hand
  • stevenb
13 years 7 months ago #68571 by stevenb
cheers marky . i managed to pick up a ball joint splitter today plus some grease so i,m going to try and get a few hours on it tomorrow . i know i need to replace the 2 disc backing plates as there roten so i,ll have to see if i can pic up a set off them well thats if i can get them off lol
Time to create page: 0.105 seconds
