General queries on a 1.3Jimny engine
  • mickt
13 years 7 months ago - 13 years 7 months ago #68020 by mickt
The engine code. In the log book the engine number starts with 13A......,where elswhere I have seen the engine mentioned as a 13AA!. Are they one and the same?
In the handbook the oil is quoted as 10/30. In Halfords the recommended oil in their guide shows it as 10/40 semi-synthetic. Which is the correct oil?
When I was checking the spark plugs costs with Unipart they reckoned their screens showed that the very expensive NGK IFR 6JH must be fitted or there could be damage to the engine. Yet the handbook gives 3 different plugs. The expensive one(£16 each) is mentioned as being for extremely cold climates while the other two plugs are NGK BKR6E-11 or finally NGK BKR6E can be used. The ones I found fitted are indeed the 6E's and are in good condition. Which do you recommend/use and does the expensive ones give any benefits i.e. better power,consumption or what have you?
Anyhelp/guidance would be appreciated.
Cheers, Mickt
Last edit: 13 years 7 months ago by mickt. Reason: spelling correction
13 years 7 months ago #68037 by j999pre
I've always used 10w 40 semi
If your engine its the twin cam it will be a m13a
Stick the plugs in the same as came out.
Simples!
Grey pick up Jimny
  • adamatdraycott
13 years 7 months ago #68039 by adamatdraycott
Replied by adamatdraycott on topic General queries on a 1.3Jimny engine
I have also always used 10w40 as 10w30 isn't readily available
10w30 is available as motorcycle oil... Which apparently don't contain certain chemicals cars require... Wet clutches or something
  • gus2000
13 years 7 months ago #68062 by gus2000
Replied by gus2000 on topic General queries on a 1.3Jimny engine
mickt wrote: NGK BKR6E-11 or finally NGK BKR6E can be used.
Hello, BKR6E-11 and BKR6E are identical
In the BKR6E-11 electrode air gap is factory adjusted at 1.1 mm (for twin cam engines, air gap 1 to 1,1 mm)
BKR6E not specified electrode gap factory set (for sohc engines 0,7 to 0,8 mm)
Not apply if the air gap set by the manufacturer of the spark plug, to be correct for the type of engine.
cheers
Gustavo
  • mickt
13 years 7 months ago #68162 by mickt
Replied by mickt on topic General queries on a 1.3Jimny engine
Yes to all your replies. I just asked to clarify. What about the unipart stance then on the expensive ones?
Regards, MickT
13 years 7 months ago - 13 years 7 months ago #68168 by facade
It isn't their money, and if they recommend the cheap ones and you have a problem, it will be all their fault :ohmy:
The expensive ones are good for starship mileages, the cheap ones need changing more often.
EDIT: the owners handbook recommends the iridium ones, they are first on the list, but says you can use two types of conventional plugs as an alternative, but they have to be checked more often.
Last edit: 13 years 7 months ago by facade.
Time to create page: 0.101 seconds
