4wd not working any sugestions ???
  • vitara_mad
27 Mar 2013 15:49 #67061 by vitara_mad
4wd not working any sugestions ??? was created by vitara_mad
i have a jimny but the 4wd is not working when selecting 4wd theres no light on dash & no hubs locking ive tryed replacing the switch on the transfer box but still same its not a problem ive come accross before so not sure what else to check
the transfer box is engaging 4wd as ive checked the front prop so its electrical problem i pressume
any suggestions on what else to check would be great
thanks
27 Mar 2013 16:42 #67066 by SpeeLaT
Or it could be one of your vac lines to the hubs has come off/got a hole in it. Do you have a hand vac pump to test?
  • reaper
27 Mar 2013 18:12 #67072 by reaper
Replied by reaper on topic 4wd not working any sugestions ???
As said could be an air line on the hub also check under right wing that is where the receiver lives the lines run down the drivers side radius arm and can take a hit
  • gus2000
27 Mar 2013 21:02 #67097 by gus2000
Replied by gus2000 on topic 4wd not working any sugestions ???
Check de vacuum circuit (sorry, in spanish)
and the electric circuit (in english)
Gustavo
  • vitara_mad
27 Mar 2013 23:46 #67118 by vitara_mad
Replied by vitara_mad on topic 4wd not working any sugestions ???
thats the sort of thing im looking for but in english & simple terms :cheer:
thanks gus
i don't think its as simple as the vucume pipes as its the system the tells them to lock where i think the problem is i thought it was going to be the switch in trans box as i pressume thats where it all starts from when selecting 4wd the switch tells something that its been selected & tells the hubs to lock
28 Mar 2013 06:20 #67122 by facade
The easiest place to start is with the switch on the transfer box, check there are wires connecting to it, then try joining the wires together at the plug, if this puts the light on the switch is faulty, but it is more likely to be the wires.
Time to create page: 0.174 seconds
