Replacing the wing mirror
- Cressyh
23 Mar 2013 20:45 #66698
by Cressyh
Replacing the wing mirror was created by Cressyh
Hi!
I have a 05 plate jimny and I love it to bits. unfortunately I had a minor accident with a tree which resulted in my wing mirror being damaged :S . I have bought a replacement but it is not heated like the one that was damaged! Does anyone know if this will be a problem? And if it won't be, is there a way I can replace it myself or would it be better to go to a garage?
Thanks a lot for any help!!
Cressy x
Cressy x
- adamatdraycott
23 Mar 2013 21:34 - 23 Mar 2013 21:36 #66707
by adamatdraycott
Replied by adamatdraycott on topic Replacing the wing mirror
Are you sure the new and old mirror is physically the same shape?
Mirrors have changed shape slightly over the years.
Can't help with removal and fitting, maybe someone else can
Last edit: 23 Mar 2013 21:36 by adamatdraycott.
- Sponnie
23 Mar 2013 22:12 #66714
by Sponnie
Replied by Sponnie on topic Re: Replacing the wing mirror
Dunno about the heating side of things. Buts the mirror replacement is easy and straightforward.
Sent from my Nexus 7 using Tapatalk 2
- markyp2000
23 Mar 2013 22:34 #66718
by markyp2000
Replied by markyp2000 on topic Re: Replacing the wing mirror
Pull the triangle trim off from inside the door where themirror is undo the 3 bolts unplug it and hay presto it falls off
Time to create page: 0.170 seconds
