Sammy guts in a jimny case
- Dave cc
23 Mar 2013 20:21 #66692
by Dave cc
Sammy guts in a jimny case was created by Dave cc
Never tried it but does anyone know if you can put sammy axle guts into a jimny case or is it easier just to weld some new brackets onto the Sammy cases ?
- MWells
23 Mar 2013 20:31 #66694
by MWells
Replied by MWells on topic Sammy guts in a jimny case
I believe the sammy axles are narrower than jimny axles although i could be wrong.
- Dave cc
23 Mar 2013 20:46 #66699
by Dave cc
Possibly i know Sammys were 2 inches wider than Sj i know lots of jimny axles break also i never broke any of my Sj axles so just wondered if they are better cant be that much diffrence will prob be able to make it fit
Replied by Dave cc on topic Sammy guts in a jimny case
MWells wrote: I believe the sammy axles are narrower than jimny axles although i could be wrong.
- Smoggy
23 Mar 2013 20:50 #66700
by Smoggy
Replied by Smoggy on topic Sammy guts in a jimny case
I have Sammy axles into a Sammy case with a jimny rear diff housing drilled, tapped and bolted onto the Sammy axle diff half ( if that makes sense ). Inside is a Jimny ARB locker with Sammy side gears to suit the axles which are chromo 4340 items.
- Smoggy
23 Mar 2013 20:52 #66701
by Smoggy
ps As you probably know Dave I am also running 285/75 x 16s. I have given them quite a bit of stick so far.
- TomDK
23 Mar 2013 22:00 #66713
by TomDK
Replied by TomDK on topic Sammy guts in a jimny case
Samurai axles are around 50 mm narrower than Jimny axles.
Time to create page: 0.136 seconds
