Changing from 4WD to 2WD problem
  • intello
17 Mar 2013 12:24 #66028 by intello
Changing from 4WD to 2WD problem was created by intello
Recently bought a 56 reg Jimny VVT, tried out the 4wd last week in the snow -worked very well, the problem is that when I stopped & pushed the button to engage the 2wd the 4wd light flashes on the dash & 2wd did not engage - I rocked the Jimny back & forward a couple of times & 2wd engaged. Any suggestions or advice please
  • reaper
17 Mar 2013 12:28 #66029 by reaper
Replied by reaper on topic Changing from 4WD to 2WD problem
Could be your vac hubs sticking ,, have a search on the forum there are loads of good threads on how to test and service them .
Its not a job that requires any skill so good for a novice :-)
  • vitara_mad
17 Mar 2013 13:08 #66040 by vitara_mad
Replied by vitara_mad on topic Changing from 4WD to 2WD problem
that sounds normal to me
  • gilburton
17 Mar 2013 15:43 - 17 Mar 2013 15:46 #66074 by gilburton
Replied by gilburton on topic Changing from 4WD to 2WD problem
The push button jimny can be selected on the move at lowish speeds. This only applies to 4WDH. Try it again on a slippery surface(not wet/dry tarmac but snow ok) Try pushing the clutch right down?
4WDL can only be selected at a standstill AFTER 4WDH has been selected.
It might be sticky hubs. If you try it with ign. on and engine off you should hear them clicking in/out?? :)
www.bigjimny.com/index.php/forum/7-jimny...956-4wd-high-and-low
Last edit: 17 Mar 2013 15:46 by gilburton.
18 Mar 2013 14:28 #66195 by saxj
You can change between 2H and 4H and back again while on the move up to 100kph.
You can change between 2H and 4L. Just make sure you have stopped completely, and have the clutch in.
  • gilburton
18 Mar 2013 16:33 #66219 by gilburton
Should you be travelling at just over 60 mph if you know the conditions might need 4wd?? :woohoo:
Time to create page: 0.176 seconds
