track rod ends
  • reaper
17 Mar 2013 12:20 #66027 by reaper
track rod ends was created by reaper
The rod end going to the pitman arm has a split is it the same as the others or are they all different ?
17 Mar 2013 12:57 #66034 by facade
Replied by facade on topic track rod ends
Dont know, but some motor factors sell universal rubber boots on a card, if you take the old one to them, you can usually get a match and get another year out of them.
  • markyp2000
17 Mar 2013 12:57 #66035 by markyp2000
Replied by markyp2000 on topic track rod ends
Not to shore on that but go to your local factors and see if you can get the rubber cover as it came in to themot awhile ago joints can fail if the boot is split and people stated to make replacment boots
17 Mar 2013 13:02 #66036 by mlines
Replied by mlines on topic track rod ends
All the ends are the same, except where they are different!
The difference being LH or RH thread depending on which end of the arm they are fitted.
  • vitara_mad
17 Mar 2013 13:03 #66037 by vitara_mad
Replied by vitara_mad on topic track rod ends
1 end will be right hand thread & other side will be left hand thread
best to replace the joint rather than a new rubber cover as they are only cheap
  • reaper
17 Mar 2013 13:03 #66038 by reaper
Replied by reaper on topic track rod ends
Doh didnt even cross my mind that martin lol
Thanks that answers my question
Time to create page: 0.187 seconds
