Strange noise on startup :S
  • Alex09gp
12 Mar 2013 14:00 #65415 by Alex09gp
Strange noise on startup :S was created by Alex09gp
Hi hope somebody could help me, when I start my jimny I get a strange noise from the middle of the dash area, it's a metalicy grinding noise and lasts for about 2 seconds. Does anyone know what this could be?
Thanks Alex
  • adamatdraycott
12 Mar 2013 16:11 #65426 by adamatdraycott
Replied by adamatdraycott on topic Strange noise on startup :S
Not sure what it could be.
My Jimny makes a noise as you move off for the first time… it kicks in at about 5mph and sounds like an electronic valve opening wouldn’t call it a grinding noise… more of a hum… I have always assumed it’s the vacuum system or the ABS initialising. Anybody?
The transfer box chain is said to make a machine gun like noise if its slipping.
Try starting it with your foot on the clutch.
  • Alex09gp
12 Mar 2013 16:17 #65428 by Alex09gp
Replied by Alex09gp on topic Strange noise on startup :S
It happens as soon as I stop turning the key, so not even moving. Looked through google and it would appear other makes/models do this when it is cold?
  • Goat
12 Mar 2013 17:08 #65432 by Goat
Replied by Goat on topic Re: Strange noise on startup :S
I get this. Sounds almost like the stater motor hasn't disengaged properly. Been doing it for ages.
  • Beano
12 Mar 2013 17:34 #65439 by Beano
Replied by Beano on topic Re: Strange noise on startup :S
Could be the pinion gear just getting stuck as it try's to disengage?
  • Alex09gp
12 Mar 2013 20:35 #65489 by Alex09gp
Hmmmm, sound like nothing to worry about then, did a test and took it for a run to get it up to temperature, came back turned off the car, restarted and it did not do it. Must be a cold thing lol! Thanks for your help guys.
