Air Bag Light not coming on
  • SussexRob
  • Visitor
  • Visitor
01 Mar 2013 16:17 #64279 by SussexRob
Air Bag Light not coming on was created by SussexRob
Hi all,
This is my first post here after lurking in the dark reading many a helpful post, so firstly, hi!
I have a W reg Jimny, and love it. However it got an advisory on it's last MOT, because the air bag light does not light when you turn the ignition.
I have a copy of the service manual, and plan to spend tomorrow running through the checks suggested, and will need to get to the bulb to check it.
The service manual isn't the clearest when it comes to taking apart the instrument panel, and also mentions that the steering column assy needs to be removed.
I have trawled the net for a while now, and can't find much about removing the instrument panel so I am hoping I can get some advice from you kind peeps. Do I really need to remove the steering column assy or is there a better way to get to the bulb?
Cheers!
Rob
  • markyp2000
  • Visitor
  • Visitor
01 Mar 2013 18:14 #64290 by markyp2000
Replied by markyp2000 on topic Air Bag Light not coming on
Just above the steering wheel in where the speedo is a the top on the under side are 2 screws undo them and yank it towards you then unscrew the cluster
  • SussexRob
  • Visitor
  • Visitor
01 Mar 2013 18:16 #64293 by SussexRob
Replied by SussexRob on topic Air Bag Light not coming on
Cheers for that! I had found those screws, and thought there had to be more to undo somewhere.
Well that makes things a bit easier in the morning, I just hope it is simply the bulb that needs changing.
  • markyp2000
  • Visitor
  • Visitor
01 Mar 2013 18:29 #64294 by markyp2000
Has the light ever worked i wouldnt go playing around to much on the air bag system if you dont no what your doing it may/will hurt
  • SussexRob
  • Visitor
  • Visitor
01 Mar 2013 18:34 #64295 by SussexRob
I plan to simply check the bulb, if that's not it, it'll be going into a garage, as its MOT is due this month anyway.
  • markyp2000
  • Visitor
  • Visitor
01 Mar 2013 18:47 #64299 by markyp2000
It wont fail on it trust me im an mot tester
