engine just stops!! HELP!!!!
- markyp2000
09 Mar 2013 15:53 #65063
by markyp2000
Replied by markyp2000 on topic engine just stops!! HELP!!!!
Also do you have a pic of this pipe it may plug on to some where where you cant see
- sam_516
09 Mar 2013 16:02 - 09 Mar 2013 16:06 #65065
by sam_516
Replied by sam_516 on topic engine just stops!! HELP!!!!
The cleaner stuff I am talking about is designed to clean out your engine, Subaru wrx's are renound to gum up and using the cleaner is just another part of their service, doesn't harm your engine at all and improves fuel economy by cleaning all the carbon build up allowing the engine to breath better, after cleaning mine I gained an extra 150klm to a tank! I learnt the trick off a mate who is the leading hand of a Subaru work shop, take the throttle body off and clean that seprate because there is a lot of little cavities that need extra attention but if you leave it at that all your carbon build up stays in everything behind the throttle body
Last edit: 09 Mar 2013 16:06 by sam_516.
- TonkaTough
10 Mar 2013 02:43 #65108
by TonkaTough
Replied by TonkaTough on topic engine just stops!! HELP!!!!
thanks will pull it off and clean it all out with a bit of luck ill get even better fuel econ
10 Mar 2013 10:42 #65120
by j999pre
Grey pick up Jimny
Replied by j999pre on topic engine just stops!! HELP!!!!
Where can I get that subaru gum cleaner? My wrx would benefit from some more mpg.
Grey pick up Jimny
- sam_516
10 Mar 2013 10:45 #65121
by sam_516
Only place I've been able to get it from is at a Subaru workshop it's around $20 aus a can, in the wrx it should be done at least every 2nd service but at $20 a can I'd do it every service
- markyp2000
10 Mar 2013 11:00 #65124
by markyp2000
So would mine is this sold in the uk seeing as you put a $ sign
j999pre wrote: Where can I get that subaru gum cleaner? My wrx would benefit from some more mpg.
