Electrical system
  • Beano
01 Mar 2013 09:06 #64261 by Beano
Electrical system was created by Beano
Hi folks,
When my engine is up to temp and I have the fan on (not necessarily full blast) and I pop the headlights on and press the brake my idle will shoot down to almost 100rpm. :ohmy:
This usually occurs at night when I have the heater, headlights etc on. Makes for an interesting drive because as I approach traffic lights or a roundabout for example, as I'm braking and dip the clutch to stop, the revs almost die completely. It rectifies itself and brings up the revs as soon as I let off the brake pedal.
I have got myself a charging system/battery tester but it all seems to read ok?? :blink:
Any ideas?
Tar,
Al
01 Mar 2013 17:31 #64285 by Johnniehec
Replied by Johnniehec on topic Electrical system
Bad earth, damaged wiring to the tail lights?
  • jonesyba420
20 Mar 2013 11:31 #66365 by jonesyba420
Replied by jonesyba420 on topic Electrical system
I have the same issue with my 2002 jimny, when you have high drain on the electrical system it ticks over very low almost at stalling point! when you initally turn your headlights on are they really dim untill the alternator kicks in?i thought it was just down to a rubbish/dying battery (looks like it should belong on a motor bike from the size of it lol) did you get any further with finding the source of the problem? why would it be damage to the tail light wiring?
20 Mar 2013 11:42 #66367 by mlines
Replied by mlines on topic Electrical system
The tail lighting reference is to the fact that the tail lighting passes through the metal bodywork on a rubbish grommet which fails allowing the wiring to contact the bodywork
  • jonesyba420
20 Mar 2013 12:27 #66369 by jonesyba420
would this cause that level of drain on the system? i couldnt say its specifically when i brake just seems to be low on electricity so to speak. when i initially start it with the lights on they are really dim (everything,dash lights etc) untill the alternator kicks in.
i still cant seem to update my profile on here either comes up with an error message.
  • markyp2000
20 Mar 2013 12:41 #66372 by markyp2000
Replied by markyp2000 on topic Electrical system
Dont start it with the lights on then give the alternator chance to kick in
Also the more eletric us use the harder the alternator works so your putting more load on the engine
Bet your could also have an idle contol valve problem
You need to get the alternator tested with the heater on speed 2 lights on heated rear screen on and it should charge around 14v
Time to create page: 0.288 seconds
