Jimnys dying
  • L7kvv
13 years 8 months ago #64109 by L7kvv
Jimnys dying was created by L7kvv
Recently my jimnys been getting slower and loosing torque. Its steadily getting worse. Read the fault codes amd came up with p0135. This is something to do with the o2 sensor. Changed that, cleared fault but no better. Mechanic said check plugs. I did that and they were twice the gap they should be somput a set i had lying to see if it would improve it. Engine smoother but still getting worse. Im about to change them for a new set and new oil/filter. Also gona de gunk oil first too.
Now my first thought was the cat bunged up. But mechanic doesnt think it is. Its an 01 with the g13 engine so no sensor after the cat. Anyone else any ideas
  • VAXXi
13 years 8 months ago #64111 by VAXXi
Replied by VAXXi on topic Re: Jimnys dying
You checked the fuel pump (inside the tank) and its (lack of a proper) filter? after 12 years I imagine it's filled with gunk.
  • L7kvv
13 years 8 months ago #64115 by L7kvv
Replied by L7kvv on topic Jimnys dying
No havent looked yet. Its used alot of fuel so i didnt think it was being starved. But plugs were white so it could be a bit lean..
Service didnt help, and while underneath i spotted gunk round a hub, so thats the kingpins knackered, changed other side last year
13 years 8 months ago - 13 years 8 months ago #64135 by j999pre
Replied by j999pre on topic Jimnys dying
Are you sure there isn't a lambda sensor in the cat underneath. My y reg 2001 had one with the g13bb engine. (soft top).
Also is it using water? Had gasket issues can cause a slow loss in power.
Grey pick up Jimny
Last edit: 13 years 8 months ago by j999pre.
13 years 8 months ago #64136 by facade
Replied by facade on topic Jimnys dying
I'd go with your first thought, and check if the catalyst is blocked up
  • L7kvv
13 years 8 months ago #64167 by L7kvv
Had a long and slow journey this evening coming back from viewing another car. The car got even more slower and started to hear a tiny rattle, by time i got half way back car wont rev past 2500rpm and rattling like mad. So gona rip cat out of her tomorrow. Its pretty much scrap now.
I just hope the cat is the cause of the problem, and not the result of something else
Time to create page: 0.098 seconds
