Check Engine Light
  • GuardianAngel
26 Feb 2013 19:32 - 26 Feb 2013 19:34 #64065 by GuardianAngel
Re: Check Engine Light was created by GuardianAngel
Mine always comes on after a long motorway journey. I reset it (using a code reader) and stays off until the next one.
I have tried putting in decent fuel, not the cheapy supermarket stuff but still does it.
But the MPG is normal for a stock J and performance is good. But on my list is to change the O2 sensors as a pre-caution.
Last edit: 26 Feb 2013 19:34 by GuardianAngel.
  • Tadpole
26 Feb 2013 20:44 #64086 by Tadpole
Replied by Tadpole on topic Check Engine Light
My fault related to the top sensor, since being replaced I've had no more issues hth ............... ;)
  • Tadpole
27 Feb 2013 09:47 #64110 by Tadpole
jimnyonhigh wrote: Tadpole I have seen O2 sensors prices vary, could you recommend where to get one. I seen a few on Ebay but i am not clear on what one to get.
NGK was £54 and Denso ones are £74 both with 24 month warranty, also is there Two O2 sensors on a Suzuki jimny ?
This is the one I fitted item #180927754632 hth ............. ;)
  • jerry
27 Mar 2013 19:50 #67083 by jerry
Replied by jerry on topic Re: Check Engine Light
On way to work this morning my engine check light came on :( Put code reader on tonight , PO135 ( Heated oxygen sensor)
Is this likely to be the manifold sensor ?
Thanks
27 Mar 2013 22:24 #67111 by Rhinoman
Replied by Rhinoman on topic Re: Check Engine Light
Yes, P0135 is the heater circuit on the manifold sensor.
  • jerry
28 Mar 2013 04:45 #67120 by jerry
Thanks for that Rhinoman :)
Jerry
Time to create page: 0.197 seconds
