Oil Leak?
- Jimñy aaron
- Visitor
24 Feb 2013 15:25 #63846
by Jimñy aaron
Replied by Jimñy aaron on topic Oil Leak?
Well if its dripping then you should start to think about sorting it as oil leaks only get worse its quite a job stripping chain cases off but i can only make out thats where its coming from so maybe worth getting checked out.
- Jimñy aaron
- Visitor
24 Feb 2013 15:30 #63847
by Jimñy aaron
Shut the bonnet quickly and stop looking for trouble
They all do that Sir
[/quote]
Or do what he said ^
24 Feb 2013 15:46 - 24 Feb 2013 15:48 #63849
by facade
Mine weeps oil out of there, but not enough to drip on the floor (so the sump pan is as rusty as old iron, and likely to start leaking any minute :evil: )
If you are getting more oil out, I'd check the breather pipes at the top of the engine aren't gunged up.. The one nearest the gearbox connects to the PCV valve, the white plastic thing plugged in the cam cover, this should pass air in one direction only, and rattle when you shake it. If it doesn't, get a new one as they cause idling problems.
To treat the leak, the front of the engine has to come off, quite a big job for a small leak.
Last edit: 24 Feb 2013 15:48 by facade.
The following user(s) said Thank You: SteBurns
- SteBurns
- Visitor
24 Feb 2013 16:17 #63854
by SteBurns
Replied by SteBurns on topic Oil Leak?
The breather pipes are okay and the plug rattles like it should, it ticks over fine too.
Time to create page: 0.134 seconds
