abs sensors
  • ratman
22 Feb 2013 14:49 #63620 by ratman
abs sensors was created by ratman
well i have now worked out how to check the sensors with a multi meter......but here is the problem
Back sensor one reading 1.32 the other reading 1.34 and both the front sensors reading 1.27? multi meter set on omes arrow pointing at 20 k?
which sensor is faulty? all answers welcome?
if your write you win a prize......... a faulty sensor of your choice
22 Feb 2013 22:00 #63687 by Rhinoman
Replied by Rhinoman on topic abs sensors
The resistance readings aren't usually much help but you can pull fault codes from the ABS ECU by using a jumper in the monitor coupler which should be a six-pin connector under the dashboard.
The following user(s) said Thank You: ratman
  • markyp2000
22 Feb 2013 22:19 #63689 by markyp2000
Replied by markyp2000 on topic abs sensors
Thats how i test abs sensors when my diagnostics machine dont work on older cars and as of yet its never failed me after 17 year being a mechanic next tast the wires to the abs control unit when its unpluged
23 Feb 2013 13:46 #63721 by Rhinoman
I've had a few Zuks and Mazdas where the sensor tested OK with a resistance check but turned out to be faulty. I had a look in the FSM and the Zuk ABS ECU can output fault codes so that will help narrow down the problem.
  • ratman
27 Mar 2013 09:38 #67047 by ratman
Replied by ratman on topic abs sensors
Well I have had a friend read codes with suzuki computer....its the pump!!! £1200 pound for a dealer part........found some one breaking a jeep the same year.....£30!!!! dancer all changed and working....
Thanks for help above though,best to try everything before you buy I say
  • Tadpole
27 Mar 2013 19:13 #67078 by Tadpole
Replied by Tadpole on topic abs sensors
:ohmy: Good news, money to spend on other things now ........................... :whistle:
Time to create page: 0.210 seconds
