standard spring hight
- cos124
18 Feb 2013 09:40 #62994
by cos124
standard spring hight was created by cos124
Does anyone have the hight or length of standard Jimny front springs? (i'm aware that drivers side are a bit longer.
The workshop manual hasn't got that information anywhere.
thanks
thanks
- gus2000
18 Feb 2013 12:02 #63000
by gus2000
Replied by gus2000 on topic standard spring hight
Hello, both front spring are identical. (41111-81A20)
Free height = 335 mm
Ext diameter= 112 mm
Wire diameter = 10,3 mm
7,25 turns
Gustavo
7,25 turns
Gustavo
- gus2000
18 Feb 2013 12:11 #63001
by gus2000
- cos124
18 Feb 2013 13:22 #63005
by cos124
Replied by cos124 on topic standard spring hight
smashing! thank you so much!
- cos124
18 Feb 2013 20:56 #63084
by cos124
Gus, the rear spring from the photo appears to be around the 290mm. Is that right?
Many thanks again.
Many thanks again.
- reaper
18 Feb 2013 20:58 #63085
by reaper
Replied by reaper on topic standard spring hight
Rears are 2" or 50mm shorter than fronts
Time to create page: 0.158 seconds
