Manual Hubs
- rogerdadodger
17 Feb 2013 20:44 #62920
by rogerdadodger
Manual Hubs was created by rogerdadodger
Hi all just wondered what manual hubs fit the jimny & if there's a how to or guide to swapping the vac's for manuals?
Many thanks
Many thanks
- Laminak
17 Feb 2013 22:28 #62978
by Laminak
Replied by Laminak on topic Manual Hubs
I'm going to fit Samurai manual hub
with adapter plates from jimnybits
- badboy-jimny
17 Feb 2013 22:39 #62982
by badboy-jimny
Replied by badboy-jimny on topic Manual Hubs
Thats what I have on mine now. Work a treat. Rodgerdadodger.... theres a few guides on here sonewhere. Its just a case of takin old hubs off and replacing them with the manual ones plus adapters if needed. You then block off the vac pipes as no need for them. Iv left my 4x4 light flashing so I remember im in 4wd
- rogerdadodger
18 Feb 2013 19:24 #63053
by rogerdadodger
Replied by rogerdadodger on topic Manual Hubs
Thanks for the reply Badboy. That sounds nice & easy
Which hubs fit though? SJ, Samuari? Anything else?? I thought I might as well do this as I need new ridged & rubber pipes!!
- Licksan
18 Feb 2013 19:34 #63058
by Licksan
Replied by Licksan on topic Manual Hubs
I was in the same situation. With knackered pipes. Fitted the Jimny specific AVM manual hubs from Jimnybits.
Not the cheapest but can't fault them.
I connected the vac pipes to the solenoids so the 4wd light stays on when in 4wd and then removed all the pipes from the axles, arms and hubs and soldered the open brass ends going into the hubs to stop water getting in.
