VAC HUBS
- fast forward
Topic Author
- Elite Member
- Thank you received: 7
15 Feb 2013 19:36 #62707
by fast forward
if you cant go round it go over it ! or vice versa ?
VAC HUBS was created by fast forward
hi i know vac hubs are operated by air vacum and people dont rate them but how do they work in the hub whats in there is it plastic parts / metal or what only asking as mine failed the other night in all that snow and going to have a look this weekend starting with any leaking pipes , but as said before whats in the hub ! and how do you lock them manually , :dry:
15 Feb 2013 21:42 - 16 Feb 2013 14:18 #62721
by j999pre
Grey pick up Jimny
Metal bits inside.
Sliding centre that slips over the end of the driveshaft and locks the hub.
Just whip one off and push the centre in/out.
Enjoy.
Enjoy.
Grey pick up Jimny
Last edit: 16 Feb 2013 14:18 by j999pre.
- Johnniehec
- Thank you received: 56
15 Feb 2013 23:51 #62733
by Johnniehec
Replied by Johnniehec on topic VAC HUBS
Actually it' s pull the centres out, here's the how to guide
I had to do mine when the last snow came and haven't undone them since.
www.bigjimny.com/index.php?option=com_co...drivechain&Itemid=37
- fast forward
Topic Author
- Elite Member
16 Feb 2013 13:00 #62763
by fast forward
Replied by fast forward on topic VAC HUBS
cheers for your quick replies . going out with spanners now !
- markyp2000
16 Feb 2013 14:59 - 16 Feb 2013 15:01 #62770
by markyp2000
Out/in depends how you look at it if it on the car id say it pulls it in on to the shaft but if its in your hand the it is pulled out of the hub
Replied by markyp2000 on topic VAC HUBS
Johnniehec wrote: Actually it' s pull the centres out, here's the how to guide
Last edit: 16 Feb 2013 15:01 by markyp2000.
- fast forward
Topic Author
- Elite Member
16 Feb 2013 19:50 #62803
by fast forward
thanks for your help going to have a look tomorrow why mine failed the other night in all that snow ! hoping its just a leaking vac pipe ! :S
