Question for all those in the know
- Dave cc
14 Feb 2013 22:05 #62607
by Dave cc
Question for all those in the know was created by Dave cc
Rite my blue Jim has 31x10.50x15 MTs has been some trimming done to clear wheels
Got a 2 inch Jimny bits spring lift and procomp shocks but to be honest just aint enough clearance for them tyres.
So thinking for a hour on the lathe i can make up a 2 inch body lift and throw that on there before driving day next weekend so question is will that be enuf to clear the tyres or am a i wasteing my time ????? and what else will i have to mod to make it work IE steering column etc
- oxford_bloke
14 Feb 2013 22:21 #62614
by oxford_bloke
Replied by oxford_bloke on topic Question for all those in the know
I'm on the same size tyres, and have a 2 inch body and 4.5 inch suspension lift. I trimmed my arches by 2 inches and there is plenty of clearance. It does need some wheel spacers too as she is sat on 16 inch grand vitara offset wheels and the CofG needs lowering. As for the steering take the shaft off and either extend it by welding a rod in or crack it at the flange and put some tubes in, which if you can use a lathe i hope shouldn't be a problem.
hope that makes sense as i'm halfway through my second bottle of wine
- Dave cc
14 Feb 2013 22:30 #62615
by Dave cc
Replied by Dave cc on topic Question for all those in the know
Cheers for that mate wont be running to a 4.5 lift kit bit of a budget driving day toy until she gets tray backed
So will try the 2 inch body lift with the 2 inch spring lift see what that looks like i think she is sat on SJ rims with a good offset but do have a set of 2 inch spacers kicking around here so may fit them as well
- oxford_bloke
14 Feb 2013 22:43 #62621
by oxford_bloke
I believe that if you want to enter competitions 32mm is the max size your spacers are allowed to be
- adamjimny
14 Feb 2013 22:47 #62622
by adamjimny
Replied by adamjimny on topic Re: Question for all those in the know
They will fit in arches as thats the combination i had before new lift tires etc
Sent from my GT-I9300 using Tapatalk 2
- Dave cc
14 Feb 2013 22:50 #62623
by Dave cc
Time to create page: 0.105 seconds
