Off roading after care.
  • Jimny J
13 Feb 2013 23:25 #62486 by Jimny J
Off roading after care. was created by Jimny J
As the title suggests, have people got any useful hints and tips for keeping our Jimny's in good shape after a good days off roading?
Obviously keeping them clean is important, especially underneath. But are there any spots that should be given extra attention to avoid any unwanted rust spots developing?
I regularly give mine a good clean around the arches and as much of the chassis and drive train area as possible.
But one area im always a bit dubious about is under the bonnet. Most obviously of all, the alternator...
Is there a right or wrong way to clean any mud out of the alternator and surrounding areas?
  • adamjimny
14 Feb 2013 00:04 #62491 by adamjimny
Replied by adamjimny on topic Re: Off roading after care.
I do but while its turned of with a hose pipe not a power washer
Unless not been through water or wet mud. If its been dry day then under bonnet will be fine
Sent from my GT-I9300 using Tapatalk 2
14 Feb 2013 08:14 #62497 by mlines
Replied by mlines on topic Re: Off roading after care.
Also do not be tempted to pressure wash around the swivel seals, it can force water and dirt into the hub
Sent from my HP Touch pad using Tapatalk
  • horam_jimny
14 Feb 2013 18:57 #62564 by horam_jimny
Replied by horam_jimny on topic Off roading after care.
Also don't pressure wash the radiator! I found out the hard way and flattened off and bent a small area, Do'h!
  • jimnybob
14 Feb 2013 19:33 #62568 by jimnybob
Replied by jimnybob on topic Off roading after care.
leave the mud on :P washed the bosses l200 for the first time in 5 years. its a farm vehicle so takes some abuse and is constantly plastered in mud (till the other day) washed it off and underneath the mud all the paint was still on and smooth as the day it was put on :S
Time to create page: 0.158 seconds
