jimny steering wheel quick release
- renard38
09 Feb 2013 16:53 - 09 Feb 2013 16:57 #61696
by renard38
jimny steering wheel quick release was created by renard38
Salut,
I want to mount a quick release on my jimny:
so removing the steering wheel to see how to adapt the hub.
airbag submitted: (yellow wire = airbag ; black = horn)
the Origin steering wheel hub :
removing the solenoid:
think through the tape before the fall, to prevent it from turning, just pull over and everything comes (in white in the center, the recall system indicator)
Then I welded on a disk for future quick fix release:
quick release:
Grâce à la fabrication de mon moyeu plat, le volant recule vers moi seulement de 5 mm.
Now, every evening I go with my steering wheel as arms
A+
quick release:
A+
Last edit: 09 Feb 2013 16:57 by renard38.
- Smoggy
09 Feb 2013 21:44 #61803
by Smoggy
Replied by Smoggy on topic jimny steering wheel quick release
I like the idea but if you needed to could you easily refit the original Jimny steering wheel with airbag. This would be necessary for the uk MOT.
- renard38
10 Feb 2013 11:18 #61875
by renard38
Replied by renard38 on topic jimny steering wheel quick release
it' s really easy to refit the original Jimny steering wheel with airbag
- TomDK
10 Feb 2013 11:21 #61876
by TomDK
Replied by TomDK on topic jimny steering wheel quick release
Why would you even want a quick release for the steering wheel?
It's not like it's a NASCAR racer or anything remotely similar.
- Chriscov1988
10 Feb 2013 11:23 #61878
by Chriscov1988
Replied by Chriscov1988 on topic jimny steering wheel quick release
To deter thieves I guess
- gus2000
10 Feb 2013 11:25 #61879
by gus2000
Very good work Renard....... this is very distinguished
Your weldings are very similar to mine
Gustavo
Replied by gus2000 on topic jimny steering wheel quick release
Gustavo
