strange noise /whine at around 50 mph
- treasurer
08 Feb 2013 22:41 #61619
by treasurer
strange noise /whine at around 50 mph was created by treasurer
Hi i have a 2005 jimny with the push button transfer box . it has done 80,000 miles on road only .
Over the past year i have started to hear a whinning noise at around 50 mph if you reduce speed the whinning goes if you increase speed the whinning changes note to a higher pitch then goes compleatly when you reach 60 mph .
Lifting the accelerator momentarily seems to have no effect as also coasting in neutral .
It is hard to pinpoint the sound whilst driving but it sounds behind me rather than in front .
Has anybody experianced this or got any ideas of what it could be ?
Thanks
Thanks
09 Feb 2013 10:19 #61653
by kirkynut
Replied by kirkynut on topic strange noise /whine at around 50 mph
Have you checked the oil levels in the diffs, transfer and gearboxes?
It might give away which it is if one is very low.
- treasurer
09 Feb 2013 12:37 #61673
by treasurer
Replied by treasurer on topic strange noise /whine at around 50 mph
Hi thanks for your Help.
The oil in the rear diff i changed late last year and it had a lot of metal fillings in and also stuck to the drain plug .
When i bought the car new it was serviced by the dealler but looking at the state of the rear diff oil i would say it had never been changed .
I am on my second gerbox as the first one ,a bearing collapsed and it ate itself .
I will check the oil levels when the weather improves but from apprevious visual inspection there was no leaks .
This fault does not sound the same as the last time i had geerbox trouble .
The sound perhaps coud be better described as a wah wah sound
Sounds crazy i know .
- vitara_mad
09 Feb 2013 14:41 #61685
by vitara_mad
Replied by vitara_mad on topic strange noise /whine at around 50 mph
have you checked the rear wheel bearings ????
- Skinhead
09 Feb 2013 16:03 #61690
by Skinhead
You cant get enough of the rear wheel bearings can you???
Replied by Skinhead on topic strange noise /whine at around 50 mph
vitara_mad wrote: have you checked the rear wheel bearings ????
- vitara_mad
09 Feb 2013 16:24 #61691
by vitara_mad
there my favourate job :laugh:
Time to create page: 0.298 seconds
