Help! - Rear brake cylinder bolt size needed!
  • GuardianAngel
  • Visitor
  • Visitor
08 Feb 2013 20:23 - 08 Feb 2013 20:31 #61552 by GuardianAngel
Replied by GuardianAngel on topic Help! - Rear brake cylinder bolt size needed!
Actually, it maybe a 1mm pitch. I found this link to another Suzkui forum:
www.suzuki-forums.com/suzuki-jimny-sierr...sami.html#post329011
...that has a link to a table that describes the pitches used for different bolts sizes, apparently used by Suzuki. Here is the link:
www.boltdepot.com/fastener-information/M...ic-Thread-Pitch.aspx
I could always go Titanium! www.pro-bolt.com/titanium-hex-head-m6-x-...mm.html#.URVgaR1ri5I
Last edit: 08 Feb 2013 20:31 by GuardianAngel.
09 Feb 2013 11:16 #61660 by facade
Pop the rubbers out and warm the alloy cylinder up with a blowlamp and they will come out easily.
If you have destroyed the heads you will have to grind new flats, or put a slot across them.
They may well be fine pitch.
Standard ISO pitch is 1.0 for a 6mm thread, the fine pitch is 0.75mm. The Japanese have always used pressure die-casting for alloys, with fine pitched bolts. (The alloy corrodes much quicker than the traditional British sand casting alloys, but the die-cast ones don't have dirty great holes in them)
Pop down your local fastener supplier and get a couple of each
The following user(s) said Thank You: GuardianAngel
  • GuardianAngel
  • Visitor
  • Visitor
09 Feb 2013 11:41 #61664 by GuardianAngel
Replied by GuardianAngel on topic Re: Help! - Rear brake cylinder bolt size needed!
facade wrote: Pop the rubbers out and warm the alloy cylinder up with a blowlamp and they will come out easily.
The bolts are knackered but its raining so have abandoned for the day. Freezing and hacked off.
The old man is coming over in the week with a Dremel so should be able to get them out. There is not enough room to get a drill behind the plate and get it square onto the head to drill them out.
If all else fails then I will blow lamp them as suggested, thanks for the tip.
09 Feb 2013 12:31 #61672 by kirkynut
You need a set of these:
www.machinemart.co.uk/shop/product/detai...-piece-bolt-grip-set
They are the tool you need for removing nuts or bolts that have rounded.
Then once you have got it out you can take it to compare to the ones in Halfords or to the fasteners to get replacements.
If they sheer however, you'll be buggered and will need new wheel cylinders -but they are not that expensive anyway. A motor factor may even stock the bolts if you have to get new cylinders. It's certainly not worth trying to drill the bolts out of cylinders for the cost of new cylinders.
  • GuardianAngel
  • Visitor
  • Visitor
09 Feb 2013 12:43 #61674 by GuardianAngel
Replied by GuardianAngel on topic Re: Re: Help! - Rear brake cylinder bolt size needed!
kirkynut wrote: You need a set of these:
Thanks. I've got new cylinders anyway as I am going the whole hog and rebuilding the rear brakes. No messing around now :evil:
I know the size now so I will order some decent grade stainless bolts.
09 Feb 2013 13:36 #61680 by facade
GuardianAngel wrote: I know the size now so I will order some decent grade stainless bolts.
They will seize rock solid into the alloy by the time that you have got the wheels back on. :ohmy:
Never use stainless into alloy without a good coat of an electrically isolating thread coating.
Cadmium plated or zinc passivate is more usual.
Time to create page: 0.214 seconds
