Help! - Rear brake cylinder bolt size needed!
- GuardianAngel
- Visitor
08 Feb 2013 16:54 - 08 Feb 2013 17:15 #61486
by GuardianAngel
Help! - Rear brake cylinder bolt size needed! was created by GuardianAngel
OK, so my brake saga continues down the slippery slope of doom
Having taken one of the drums off, to take the shoes off get the adjuster out to clean and service it, one of the solenoid rubber just falls off pretty much resulting in brake fluid everywhere. No problem, I have new ones I will fit those. OH NO YOU DON'T says Mr Jimny!
The brake line union nut was rusted on and rounded off with a sniff of the spanner, so I cut the line, fully prepared to rebuild the line. No problem, all I need to do is unbolt the cylinder . NO NO NO the J says again! These have rusted up and rounded off in no time.
Now I need to drill the heads off and find replacement bolts
So, I need to know the size and thread pitch of the rear bolts that hold the brake cylinders onto the back plate. Does anybody know? I will email the manufacturer anyway to ask, but just in case anybody here knows...
I want to cry very hard......
Last edit: 08 Feb 2013 17:15 by GuardianAngel. Reason: Solenoid to cylinder
- markyp2000
- Visitor
08 Feb 2013 18:23 #61495
by markyp2000
Replied by markyp2000 on topic Help! - Rear brake cylinder bolt size needed!
Normal 10mm bolt head size will fit from any one that sells bolts take the wheel cylinder with you and then you will no as for the pipe union that may be main dealer only if i remenber smoogy had truble finding new ones
08 Feb 2013 18:53 #61509
Replied by mlines on topic Help! - Rear brake cylinder bolt size needed!
The brake pipe unions etc. are pretty standard, let me know if you have problems as I have a couple of boxes of the male and female ones in the garage.
- GuardianAngel
- Visitor
08 Feb 2013 19:04 - 08 Feb 2013 19:06 #61511
by GuardianAngel
Replied by GuardianAngel on topic Help! - Rear brake cylinder bolt size needed!
The unions are not the problem, they are M10 bolts with a 1mm thread pitch. Halfords do them, and I also have some brass ones which I will fit to the cylinders as they wont rust up.
Its the bolts that hold the brake cylinder to the rear back plate they I need replacements for. They are smaller than 10mm across (thread diameter), probably about 5mm.
Last edit: 08 Feb 2013 19:06 by GuardianAngel.
- gus2000
- Visitor
08 Feb 2013 20:01 #61536
by gus2000
Replied by gus2000 on topic Help! - Rear brake cylinder bolt size needed!
hello
suzuki part 01550-06123 BOLT (6mmX12mm)
gustavo
gustavo
- GuardianAngel
- Visitor
08 Feb 2013 20:10 #61544
by GuardianAngel
Do you remember last time you helped me and I said I could kiss you? Well this time..............
Many thanks again! I don't suppose you know the thread pitch? I have Googled the part number but I cant find the information.
