Brake problem
- pickard
07 Feb 2013 18:37 - 07 Feb 2013 22:04 #61333
by pickard
Brake problem was created by pickard
Hello all,
New member here and need a bit of help.
MOT today and failed on off side front brake performance. The garage stripped down the caliper, freed everything up but still the performance is down. Replaced the brake hose in case it was deteriorating from the inside and...performance still not up to MOT standard
They are not that familiar with the jimny, but it is a garage I trust to do good work, but they are stumped. Is there anything they ought to be looking at to solve this? I need the vehicle back on the road (and off!) but money is not readily available to sling at it willy nilly on hunches and could be's.
So, if anyone has any suggestions I (and I dare say the garage) would be much appreciative
Last edit: 07 Feb 2013 22:04 by pickard. Reason: corrective text
- Dave cc
07 Feb 2013 18:50 #61338
by Dave cc
Replied by Dave cc on topic Brake problem
Check out posts from Gaurdian angel he has been having a mare its like reading the war and peace of brake woes mite help you a bit :laugh:
- markyp2000
07 Feb 2013 19:43 #61360
by markyp2000
Replied by markyp2000 on topic Brake problem
How about swoping the calipers side to side if the problem moves to the other side you no its the caliper if not then swop the pads and see how i goes from there
- pickard
07 Feb 2013 20:22 #61372
by pickard
Replied by pickard on topic Brake problem
Thanks for the suggestions so far, I have waded through all 120 pages of owners issues on here, but not found one that replicates this particular problem.
I cannot find guardian angels post either!, tried the search function, but to no avail.
I am hoping it is not master cylinder related,
Has anyone got a diagram of the braking system they could post , there might be some sort of valve in the system the garage might be overlooking.
- markyp2000
07 Feb 2013 21:10 #61388
by markyp2000
There is a load conpensator valve at the rear but that shouldnt affect it you can see the brake pipes from the master cylinder to the brakes also did thay tell you what the readings was cos if it was low performance it would cause an imbalance and fail on that as well
- GuardianAngel
07 Feb 2013 22:16 #61405
by GuardianAngel
Dont tell me about it
Pickard, my problem is the pedal goes to the floor occasionally but most of the time its Ok.
Thread of all my woes (and others) can be found here: www.bigjimny.com/index.php/forum/7-jimny...-brake-problem-again
I face yet another Saturday under the J replacing parts...
Replied by GuardianAngel on topic Re: Brake problem
Dave cc wrote: Check out posts from Gaurdian angel he has been having a mare its like reading the war and peace of brake woes mite help you a bit :laugh:
