keeps stoping
- nicho
07 Feb 2013 18:09 #61325
by nicho
keeps stoping was created by nicho
Not ran it for a few week,bat was well and truly flat got gfs car and put jump leads on,i can start it but when i take jump leads off it stops,not right away if i rev it a bit but that only works for 20 seconds or so,dose bat just need a proper charge or is it alternater or sumet ta.
- reaper
07 Feb 2013 18:12 #61327
by reaper
Replied by reaper on topic keeps stoping
Probably battery fooked
If you have a multimeter test the battery then test it with car running (13+v at least with it running)
If you get low v with car running thats your alternator
- nicho
07 Feb 2013 18:17 #61328
by nicho
Replied by nicho on topic keeps stoping
ta would that work running it on jump leads.prob just battery like you sead.
- markyp2000
07 Feb 2013 18:21 #61329
by markyp2000
Replied by markyp2000 on topic keeps stoping
A car should run once started even if the battery is flat or removed as the alternator would run your car
- Dave cc
07 Feb 2013 18:31 #61332
by Dave cc
Replied by Dave cc on topic keeps stoping
Either charge the battery with a charger or leave your jump battery connected and run the car for a while a altenator requires a exciter voltage to make it work in other words it need a 12volt feed if it is that flat and you remove the jump leads it will not get that voltage and will not charge unlike a dynamo that can charge a battery from stone flat
- JivingDaddy
07 Feb 2013 18:59 #61343
by JivingDaddy
Replied by JivingDaddy on topic keeps stoping
I need an "exciter voltage" to get me going as well. I'll get the wife to give it a try. Fingers crossed.
Time to create page: 0.174 seconds
