Starter motor
- 2013gary
06 Feb 2013 10:43 - 06 Feb 2013 10:44 #61083
by 2013gary
Starter motor was created by 2013gary
Hi everyone,
I am in need of a new starter motor as I'm getting wet and muddy crawling underneath to tap it with a hammer. Are the Jimny starter motors all the same? I'm probably going to get one off of eBay and don't want to be stuck with one that doesn't fit. I have a 2000 JLX hardtop with the SOHC engine if that helps.
Last edit: 06 Feb 2013 10:44 by 2013gary.
06 Feb 2013 12:24 #61090
by kirkynut
Replied by kirkynut on topic Starter motor
You could contact Camsuzuki and ask them. They are likely to have what you want and will know which is the right one.
- vitara_mad
06 Feb 2013 13:22 #61101
by vitara_mad
Replied by vitara_mad on topic Starter motor
you will need 1 from a sohc as the dohc starter is differant
vitara & sj 1.3 use same starters as the sohc jimny
- 2013gary
08 Feb 2013 10:25 #61446
by 2013gary
Replied by 2013gary on topic Starter motor
Thanks both for the help - I called Cam Suzuki and should have a replacement today.
Time to create page: 0.148 seconds
