vibration second gear when accelerating
  • littlegreenjimny
13 years 9 months ago #60852 by littlegreenjimny
vibration second gear when accelerating was created by littlegreenjimny
Hi Guys
I get a fairly harsh vibration at the rear of my jimny
2000 1.3 hard top jimny
Drives fine apart from when acceleating in 2nd gear, its only when i first change into second, once i build up a bit of speed the vibrations goes.
It does not do this when slowing down or any other gears
Any thoughts?
13 years 9 months ago #60855 by mlines
I would guess Universal Joint.
Either the rear one on the main prop (most likely) or the one on the mini prop (less likely)
The following user(s) said Thank You: littlegreenjimny
  • MWells
13 years 9 months ago #60856 by MWells
Replied by MWells on topic vibration second gear when accelerating
Is it between 1600 and 1900 rpm? if so mine does the same and i haven't found a cure. I just change in to second later or put up with it. :whistle:
  • littlegreenjimny
13 years 9 months ago #60864 by littlegreenjimny
Replied by littlegreenjimny on topic vibration second gear when accelerating
where would one buy the universal joint, i find suzuki parts terrible to get hold of!
  • MWells
13 years 9 months ago #60868 by MWells
The shop on here sells them.
  • markyp2000
13 years 9 months ago #60873 by markyp2000
Replied by markyp2000 on topic vibration second gear when accelerating
I had a bad vibration felt like it was from the rear turned out to be one of the vaccum hubs stuck on
Time to create page: 0.101 seconds
