Very poor mileage, need some suggestions
  • FIRSTJIMNY
  • Visitor
  • Visitor
04 Feb 2013 15:05 #60845 by FIRSTJIMNY
Very poor mileage, need some suggestions was created by FIRSTJIMNY
The mileage on my '01 Jimny has decreased drastically in the last few months. I'm getting between 175 and 215 kilometers per tankful. I am about to change the coil and if necessary after that the lambda sonde sensor. These are the two things that showed to be a problem on the diagnostic test.
If anyone else has had a similar problem I would appreciate hearing what you have to do fix the problem, and yes, I have checked for fuel leaks. I am running 215/75/15 tires and recently put in a t-case with 4.16 gears but mileage had gone away before the t-case installation.
Thanks.
  • Dave cc
  • Visitor
  • Visitor
06 Feb 2013 23:36 #61245 by Dave cc
Replied by Dave cc on topic Very poor mileage, need some suggestions
Yeah convert it to Diesel :whistle:
07 Feb 2013 05:49 #61260 by facade
A faulty oxygen (lambda) sensor, the one at the manifold before the catalyst, will cause high fuel consumption.
  • jimnycricket
  • Visitor
  • Visitor
07 Feb 2013 08:15 #61267 by jimnycricket
Replied by jimnycricket on topic Very poor mileage, need some suggestions
FIRSTJIMNY wrote: The mileage on my '01 Jimny has decreased drastically in the last few months. I'm getting between 175 and 215 kilometers per tankful. I am about to change the coil and if necessary after that the lambda sonde sensor. These are the two things that showed to be a problem on the diagnostic test.
Thanks.
what tyres are they i changed my tyres on a Vitara and it changed by 5mpg they tyres before and after
both were mud tyres.. changed from a remould to a branded tyre
Lee
  • FIRSTJIMNY
  • Visitor
  • Visitor
17 Feb 2013 16:18 #62874 by FIRSTJIMNY
Replied by FIRSTJIMNY on topic Very poor mileage, need some suggestions
I have changed the coil and the motor immediately started running better. still going through the first tank of gas so don't know yet if it has improved.
My tires are Fedima Frontieroso 215/75/15s.
The results from the tests showed the coil and lambda sonde to be the problems. The service also toldl me that unless we replace the lambda with a factory part that chances are good that it still will not operate correctly. Has anybody tried the aftermarker lambda's?
  • jimnybob
  • Visitor
  • Visitor
17 Feb 2013 16:25 #62876 by jimnybob
Replied by jimnybob on topic Very poor mileage, need some suggestions
get an lpg conversion ;)
Time to create page: 0.148 seconds
