Front radius arm help asap
  • Chriscov1988
02 Feb 2013 08:29 #60627 by Chriscov1988
Front radius arm help asap was created by Chriscov1988
Hi guys I'm changing my front arms this morning with a set from rhino ray and not much mechanical knowledge. Could someone give me some tips or point me in the direction of a "how to"?
Can I change 1 side at a time or do I need to get both sides off and then replace the 2 new ones at the same time.
Thanks Chris
  • TomDK
02 Feb 2013 09:13 #60629 by TomDK
Replied by TomDK on topic Front radius arm help asap
If they are castorcorrecting, just remove both of them and the install the new ones.
  • markyp2000
02 Feb 2013 10:21 #60632 by markyp2000
Replied by markyp2000 on topic Front radius arm help asap
When i did mine i put it on ramps chocked the rear wheels the front axle shouldnt move when the arms are remved
  • vitara_mad
02 Feb 2013 11:35 #60641 by vitara_mad
Replied by vitara_mad on topic Front radius arm help asap
i fitted them one at a time when i fitted 3" caster correction arms from ora
  • adamjimny
02 Feb 2013 12:07 #60644 by adamjimny
Replied by adamjimny on topic Re: Front radius arm help asap
Put handbrake on and chock back wheels then you can do one at a time but you will only be able to attach one bolt axle end until the other arm is also on
Sent from my GT-I9300 using Tapatalk 2
  • Chriscov1988
02 Feb 2013 12:15 #60646 by Chriscov1988
Replied by Chriscov1988 on topic Front radius arm help asap
Right I'm all done. Was fairly straight forward and only took an hour and a half if that. The difference when driving before and after is like night and day. It doesn't feel as dangerous anymore and the steering doesn't snatch when you get to a certain point so in quite pleased.
The difference between the two:
One side before:
Other side after:
The wheels are a little turned in the second pic so it makes it look a little bit worse but the difference is noticeable.
Fitted:
Will have these standard arms with CC bushes in for sale now. Any ideas what they will be worth?
And finally I took the rear seats out and tidied up my tools, straps etc
And now to clean my other love:
Thanks
Time to create page: 0.164 seconds
