4WD syst - no "CLACK CLACK" from my HUBS
  • wanderinstar
03 Feb 2013 17:02 #60764 by wanderinstar
Replied by wanderinstar on topic 4WD syst - no "CLACK CLACK" from my HUBS
From reading this post and due to the language difficulty. Now I may be wrong, but do you expect the hubs to "clack-clack" all the time you are in 4wd or just when you first engage it?
  • Laminak
03 Feb 2013 19:30 #60781 by Laminak
Replied by Laminak on topic 4WD syst - no "CLACK CLACK" from my HUBS
wanderinstar wrote: From reading this post and due to the language difficulty. Now I may be wrong, but do you expect the hubs to "clack-clack" all the time you are in 4wd or just when you first engage it?
Excuse me for my language difficulty :blush: , but I am a French boarder and my english is very bad :blush: :blush:
To answer to your question, the "clack-clack" is for the first engage. :)
But today, I remove the right hub and beurk :dry: ... I find water and dust :sick:
Facade said: Check the wheel bearings.
If the bearing is worn there will be a vacuum leak that stops the hub releasing.
I think it is my bearing lip seal wich it 's dead :sick: :sick:
  • wanderinstar
04 Feb 2013 10:25 #60828 by wanderinstar
I am sorry. I didn't mean to be offensive. Just wanted to clear it up because you was not very clear about when the clack sound sounded. Luckily I have not had the problem.
Hope you get it sorted.
  • Laminak
04 Feb 2013 11:00 - 04 Feb 2013 11:07 #60833 by Laminak
wanderinstar wrote: I am sorry. I didn't mean to be offensive. Just wanted to clear it up because you was not very clear about when the clack sound sounded. Luckily I have not had the problem.
Don't worry B) ... you did not offend me B) B) ...
It is difficult for me to find my words :( ... But, every days, I read several posts on BigJimny forum and I try to improve my English B) B) B) ...
Last edit: 04 Feb 2013 11:07 by Laminak.
  • wanderinstar
04 Feb 2013 12:13 #60836 by wanderinstar
Good for you. That is the way to learn. Have you tried jacking one front wheel up and end engaging 4wd. Then see if that wheel turns. Then do the same with other wheel then push lever forward to disconnect 4wd and see if wheel turns freely then.
At least that way you will know for definite. "Clack -clack" or not.
  • Laminak
04 Feb 2013 12:50 #60838 by Laminak
I have jacking one front wheel and I have engaging the 4WD... But my wheel turns freely :-(
I define "Clack -clack" as the locking of each hub :-)
Time to create page: 0.162 seconds
