4WD syst - no "CLACK CLACK" from my HUBS
- Laminak
01 Feb 2013 09:27 #60513
by Laminak
4WD syst - no "CLACK CLACK" from my HUBS was created by Laminak
Hi all
I have a problem too with my 4WD system :sick:
I change all my caoutchouc vacuum hoses by silicon hoses.
One of pipe was blocked. I freed it (is it correct :whistle: ).
All my servo-valve are ok and I have no flashing light
My vacuum intake operates (jimny 2001)
But I have no "clack clack" from my hub :dry: :dry: :blush: :blush: .
Do you think that I have leak in my vacuum pipes or my vacuum Hubs???
Perhaps , I have a leak on the lip-seal track from my hubs :sick:
I make a better picture later
What do you think about some ideas ???
Heeeeeelp
- increase the vacuum to compensate the leak
- invert the system and using pressure to close my hubs
- repair the track
Heeeeeelp
- GuardianAngel
01 Feb 2013 10:34 #60516
by GuardianAngel
Replied by GuardianAngel on topic Re: 4WD syst - no "CLACK CLACK" from my HUBS
Its funny because my 4WD system works but I have never heard the hubs engage.
- markyp2000
01 Feb 2013 10:43 #60519
by markyp2000
Replied by markyp2000 on topic Re: 4WD syst - no "CLACK CLACK" from my HUBS
Make shore you have the pipes the right way round ie is it sucking them off instead of sucking them on
- GuardianAngel
01 Feb 2013 10:54 #60522
by GuardianAngel
Getting sucked off :blush:
Replied by GuardianAngel on topic Re: Re: 4WD syst - no "CLACK CLACK" from my HUBS
markyp2000 wrote: Make shore you have the pipes the right way round ie is it sucking them off instead of sucking them on
- JivingDaddy
01 Feb 2013 11:26 #60524
by JivingDaddy
Replied by JivingDaddy on topic Re: Re: 4WD syst - no "CLACK CLACK" from my HUBS
- Laminak
01 Feb 2013 11:28 #60525
by Laminak
Replied by Laminak on topic Re: Re: 4WD syst - no "CLACK CLACK" from my HUBS
I use a vacuum pump tool to test my pipes to suck. But it is getting sucked off :blush: :blush:
But, when I use a pressure my hubs operate. The pressure is higher than the vacuum pressure and then make operate my hub :blink: . It is for that I think I have a leak to my hubs :blush:
Time to create page: 0.283 seconds
