Twin battery conversion.
  • Chriscov1988
30 Jan 2013 13:38 #60241 by Chriscov1988
Twin battery conversion. was created by Chriscov1988
What do I need to do one?
I have the battery so just need to find somewhere to mount it.
Do you just join the two together?
Will the standard alternator be enough to run 2 batteries? Any help would be appreciated.
Thanks Chris
  • Blissett
30 Jan 2013 14:20 #60246 by Blissett
Replied by Blissett on topic Twin battery conversion.
You cannot just join them together they will discharge each other. Depend on what you want the second battery for. If its to power low power stuff you could use a caravan charging module. If for winching then you need a proper split charge system.
If you move the washer bottle forward there is room for a battery you will need to fab a tray and mounts..
Have fun
Mark
  • gus2000
30 Jan 2013 14:29 #60247 by gus2000
Replied by gus2000 on topic Twin battery conversion.
Hello, for connect two batteries in parallel is necessary that both are exactly same. (Same electrochemical voltage). Of not being this way, an it is discharged on the other one
Use , for example, warn isolator to avoid this problem.
www.warn.com/truck/accessories/battery_isolator.shtml
Gustavo
  • Dave cc
30 Jan 2013 17:04 #60258 by Dave cc
Replied by Dave cc on topic Twin battery conversion.
Twin altenator set up i have 1 running front winch and second running rear winch and other electrics on the truck works good
