Water in engine oil.
- HolmarH
29 Jan 2013 18:50 - 05 Feb 2013 17:52 #60155
by HolmarH
Water in engine oil. was created by HolmarH
Hi.
I replaced the head gasket about a month ago. Now I got water in the engine oil again.
I was wondering if you would know about some common problems similar to this in the jimny engine.
Probably the cylinder head that has a crack in it what do you guys think?
Last edit: 05 Feb 2013 17:52 by HolmarH.
- markyp2000
29 Jan 2013 19:12 #60160
by markyp2000
Replied by markyp2000 on topic Water in engine oil.
Remove the rocker cover and under the camshaft in the center there should be a core plug i think thay crack there but bont hold me to that
why do you say its got water in the oil that looks like new oil to me on the dip stick
- HolmarH
29 Jan 2013 21:24 #60189
by HolmarH
Replied by HolmarH on topic Water in engine oil.
Thanks.
It has water in it, the picture isn't good enough, if you look close at the end of the stick is a grey oil wich is mixed with water.
(sorry for bad English from Iceland
- markyp2000
29 Jan 2013 21:40 #60196
by markyp2000
How well did you flush/clean out the engine oil system did you remove the sump and clean it out or just drain old oil out and then refilled with new
- markyp2000
29 Jan 2013 21:42 #60198
by markyp2000
Also water in oil goes thick creamy colour but oil in water goes sludge and gray
- gus2000
30 Jan 2013 01:28 #60219
by gus2000
Replied by gus2000 on topic Water in engine oil.
decrease the quantity of water in the recipient?
it can be residual water in the carter of the previous repair
gustavo
gustavo
Time to create page: 0.112 seconds
