Grinding when 4wd is engaged
  • Nelson83
26 Jan 2013 17:33 #59719 by Nelson83
Grinding when 4wd is engaged was created by Nelson83
I've noticed that when i engage 4wd there is a grind noise coming from somewhere - when i dip the clutch to engage 4wd on the move it grinds and when traveling in 4wd it grinds intermittently :unsure: I had a replacement axle put on this time last year after it was grinding constantly when i 4wd (it was so bad i thought the axle was about to rip itself off) - then it turned out to be a nackered diff :sick: :sick: Any body got any ideas as to what it could be? It only does it when the clutch is dipped and when the 4wd is engaged. I have noticed that if i switch to 4wd before starting and drive it doesnt grind, only when its been running for a few miles does it start to do it.
  • badboy-jimny
26 Jan 2013 18:54 #59745 by badboy-jimny
Replied by badboy-jimny on topic Grinding when 4wd is engaged
Hello mate, I had a loud grinding from the front end every now and again which eventually became more and more. Sounds similar to that what your saying. Someone suggested one of the hubs was engaging on and off causing it to grind while driving. I had the king pin bearings do e first then my 4wd broke so have now got manual hubs on. No noise now at all. Maybe same story with your
  • Nelson83
26 Jan 2013 19:18 #59747 by Nelson83
Replied by Nelson83 on topic Grinding when 4wd is engaged
ive had one king pin and swivel done in the last 4 months, and thought the other side had started to go, but the death wobble stopped, so i haven't worried about too much since. I did think it was the hubs last time but the garage stripped the diff and it was knackered - they didnt do anything until id been down and looked at the inners - it was well past saving. Im tempted to get some free wheeling hubs, but need to wait until pay day now :(
  • badboy-jimny
26 Jan 2013 19:24 #59748 by badboy-jimny
Well im not to sure what it was but its stopped now. I too only had one side done of the bearings and sure now I need other done. I picked sone hubs up on here for a good price....but its all money aint it. I have a snorkel sat here waiting for pay day to be fitted too! Good luck finding problem though
  • Nelson83
27 Jan 2013 06:30 #59793 by Nelson83
I have noticed that the noise doesnt happen below 30mph and doesnt happen in low box either. Did your 4wd light flash when your hubs went? Mines still saying on all the time atm
  • badboy-jimny
27 Jan 2013 08:37 #59800 by badboy-jimny
It started like that then got worse. The light stayed on as normal at first and eventually after a few weeks started flashing. Every now and again it would stay on too. Id had enough so bought hubs and had vac system blocked off. Works sweet now mate
