Another Kingpin related topic. Sorry!
- horam_jimny
26 Jan 2013 14:55 #59677
by horam_jimny
Another Kingpin related topic. Sorry! was created by horam_jimny
Hi Guys,
Sorry to be starting yet another kingpin topic but after searching the archives I couldn't find the answer.
Firstly after reading the "How to" guides (very helpful!) I'm confident I can tackle the job but my only concern is removing the bearing cups. In the guide there is a handy tip for welding a spot onto them to aid getting them out. Unfortunately I don't have access to a welder so does anyone have any good easy tips for getting these out? I really don't want to end up with the hubs and joints all in pieces on the floor and no way to remove them!
Secondly I'm also sure the nearside wheel bearing has also gone as I can hear a ticking/vibration coming when cornering to the right at about 40-50mph (ie nearside wheel is under load). I have bought the kingpin repair kit (plus grease and sealant) from Bigjimny.com but not got the wheel bearings and hub tool yet. What I want to know is if I replace the kingpins and oil seal but not the bearings yet (as cant afford it) will the bearing then wear the new oil seal and cause problems? So should I change the kingppins now and the wheel bearings in a month or two or wait for the new wheel bearing and replace the lot?
Cheers guys
Cheers guys
- Sponnie
26 Jan 2013 15:09 #59683
by Sponnie
Replied by Sponnie on topic Another Kingpin related topic. Sorry!
I knocked the bearing races out with another socket and socket extension. Easier than the welding method.
- markyp2000
26 Jan 2013 15:35 #59695
by markyp2000
Replied by markyp2000 on topic Another Kingpin related topic. Sorry!
A long drift/punch in the in side edge hitting at 12 oclock 6 oclock 3 9 12 6 3 9 and so on till its out
26 Jan 2013 18:52 #59743
by facade
Replied by facade on topic Another Kingpin related topic. Sorry!
As above for the removal.
Check the tyres back and front for nails in the tread before you change the bearing
Time to create page: 0.076 seconds
