Tyre pressures and locker use?
- Smoggy
13 years 9 months ago #59640
by Smoggy
Tyre pressures and locker use? was created by Smoggy
As most of you know, I have independently selectablefront and rear ARB lockers and beadlocked 285/75 16s. I have relatively little experience of off roading but now have all my goodies working
My question is when and how is the best time to use my lockers; front, rear or both and what should I reduce my tyre pressures down to. I am going to play in the snow before it goes
Thanks.
Thanks.
- TomDK
13 years 9 months ago - 13 years 9 months ago #59642
by TomDK
Replied by TomDK on topic Tyre pressures and locker use?
It all depends on terrain.
But when going straight ahead u can easily use both front and rear locker. But disable front when turning
Tyre pressure. Below 0.5 bar if needed
But I'd say just go out and give it a try
Last edit: 13 years 9 months ago by TomDK.
- Paul4x4
13 years 9 months ago #59643
by Paul4x4
When to use them... Well, that one you have to learn yourself, but I would say keep the rear one always locked when offroading, and lock up the front right before you hit the mud or try to get the front end up on some rocks or something. Just use it at the right time, because if you're already stuck in some bog, locking the front at that point probably won't help you much. Basically, lock it, drive through/over the obstacle, and unlock.
Replied by Paul4x4 on topic Tyre pressures and locker use?
Yeah, 0.3-0.5 is good!TomDK wrote: Tyre pressure. Below 0.5 bar if needed
- Sponnie
13 years 9 months ago #59656
by Sponnie
Replied by Sponnie on topic Tyre pressures and locker use?
No idea. But im very jealous of your set up!
- Barnyzuki
13 years 9 months ago #59664
by Barnyzuki
Replied by Barnyzuki on topic Tyre pressures and locker use?
I have a Lockright in the back of mine and it tends to push the front wide when setting off round corners in the snow, mind you it is on slick road tyres atm.
I also found out the Jimny is light enough for one man to push back onto a snowy track when it slid off and leant against a drift :laugh:
- Dave cc
13 years 9 months ago #59665
by Dave cc
Replied by Dave cc on topic Tyre pressures and locker use?
Personaly wouldnt use either unless required when i lock the rear on my Yota i would stay steering is compromised by around 25% just wants to push on lock the front and you might as well take the steering wheel off and put it in the glove box with your set up unless you end up on some mad cross axle Bog then be very suprised if you will get stuck if you do however drop y rear locker in (not with wheels spinng madly) and it will just drive out
Time to create page: 0.103 seconds
